- 17 Jan 2006
I hope this is still working, my Ultimate runs out in about a month and I was hoping to stack the gold and convert so I don't have to worry for the next three years.
Same here, hopefully still working. To be honest I hardly play Game pass games unless there is an exclusive I like. But still feel the need to have it, just in case...I hope this is still working, my Ultimate runs out in about a month and I was hoping to stack the gold and convert so I don't have to worry for the next three years.
Just did this for my sons sub. Nice and easy again.Just did this using CD Keys: Turkey Xbox Live 12 month codes (£24.99) x 3 (you have to search for them otherwise it'll just give you the UK codes- more expensive)
Used HolaVPN on chrome to switch to Turkey and redeemed via https://redeem.microsoft.com/
Then upgraded to Game Pass Ultimate for £10.99 (no longer offers you the £1 upgrade), works out approximately £2.39/ month in total
Is this still the best way? Mine runs out on FridayJust did this using CD Keys: Turkey Xbox Live 12 month codes (£24.99) x 3 (you have to search for them otherwise it'll just give you the UK codes- more expensive)
Forgive the noob question please... Do you still have to use a vpn when playing the games? Or does it not matter which country you are in once the subscription has been paid?Just did this using CD Keys: Turkey Xbox Live 12 month codes (£24.99) x 3 (you have to search for them otherwise it'll just give you the UK codes- more expensive)
No, you only need a VPN for adding the Gold codes to your Xbox account.Forgive the noob question please... Do you still have to use a vpn when playing the games? Or does it not matter which country you are in once the subscription has been paid?
No you have to wait until it has expired.Can you still do this if you have time left? Think my 3 years are up in October. I guess I can add 2 years worth now?
If you try and add Gold codes while you still have an active Game Pass sub they convert the Gold to Game Pass which I think is 12 months Gold = 4 months ultimate or something pretty low. Definitely wait.
I did these via my PC and used Norton as my antivirus comes with a VPN and saved having to install browser plug in or anything which I wouldn't trust.
Once the codes were registered I went onto my Xbox as usual and selected the option to upgrade to Game Pass and was charged 10.99 and that was it.
I don't think so, I'm no expert but everything I've seen posted/discussed says you need your sub to expire before renewing.Can i cancel it now if its expiring december and renew if for 3 years from now?
Yep, you can buy gold for the UK which is £35.99 per year on cd keys and then do the upgrade which will convert it to ultimate.Does this still work if you don't get the Turkish live? I haven't got a VPN
I love that this still works and it's wild microsoft stil allowsnit even though they know people are exploiting this like mad
MS don't care it seems, I had an issue with it and phoned them. The boy on the phone basically walked me through it.
The amount doing it are probably minimum and then forget to cancel the rolling subscription and pay for months without noticing.
