Your advice please, custom build from OCUK arrived yesterday but one issue :
Depending on your broadband speeds a TP-Link TL-WA850RE can be had for around a tenner, it's a plug/booster that comes with ethernet ports so you could just plug it in next to the PC and run the cable into NIC.
Might be a faff to setup if you're not used though, a wireless adapter is by far the easiest solution.
oooo that's neat!
and we have lift off, working, still had to download the drivers for the adapter, move to a USB and port across.
Sorry if I was a little overzealous earlier but god I hate technical issues.
wow thank you. I mean, as much as I appreciate the advice when it came to purchasing, almost feels like some kind of sick joke. Why in 2025, would anyone recommend a motherboard that does not support WiFi.
I'm not sure what my options are now, move my modem upstairs the only viable one? Not even sure if that is possible as I live in a flat and it's connected to the wall
Can i buy an adaptor of sorts? I get I should have double checked it but pffffffffffffffffffffft
I never use WiFi on my computers. It's not as reliable as a wired connection so cost or what year it is would be irrelevant for me. I'm sure if it was a requirement, the nice people on here would have recommended a motherboard with WiFi :)
Glad you got everything sorted :)
My board has Wifi but I do not need or want it but got the board due to it being a good price.
As others have said, if it was essential it should have been said and you should never assume anything when asking for assistance from random people on a forum.
hope the dongle sorts out the issue
Spoke too soon, connection keeps dropping out which is infuriating.
Also, installed wow classic and every time I go to launch it, it crashes.
Pulling my hair out here. Windows update all complete along with GPUT drivers
You know the noise when you plug and uplug a usb, that’s happening but think it’s signifying the internet connection dropping.
So stressful :( - not only will it not connect to the net, it’s crashing every time I run wow.
That indicates that an USB device has been disconnected and reconnected.
When this happens does the adaptor disappear and re appear in device manager?
As its USB it might be worth disabling USB selective suspend from Windows power plan to make sure its not disconnecting due to power saving.
Thank you, I have just disabled it.
With warcraft, uninstalled and trying to reinstall again
Ring OcUK tomorrow and seek advice. You shouldn't be getting any issues with a newly built and tested PC...
I don't think they are at fault at all. I think its just a case of should have ordered the MB which supports wi-fi and looks like it's an AMD driver issue with WoW.
i've not heard of any radeon driver issues with wow, what issues are you having?
He opened a different thread for it:
these are great, they use your home wiring to transmit broadband from the router to a plug somewhere else in the house
even if they are plugged into different rings, my son has one upstairs for more stable connectivity than wifi and gets about the same speed, and ping as me , plugged right into the router .downstairs
not exactly cheap, but brilliant none-the-less
ours came with an ethernet cable long enough to connect the transmitting plug in a socket closest to the router, so you don't need to buy an extra lead for the router end, but you will need a ethenet cable long enough to reach from your computer to the nearest free socket,
My basket at OcUK:
Total: £43.99 (includes delivery: £3.99)​
The motherboard also doesn't support bluetooth. More bad news given my headsets work via bluetooth
Honestly, I'd rather just order another motherboard and get everything fitted again but it this even a viable option with the CPU already in place please?
An bit of a disaster this, £1900 spent - no bluetooth, no wi-fi and can't play World of Warcraft which was pretty much the main objective of building this new PC.
Thank you @Threepwood
I guess it would be cheaper to buy this and a wired headset than getting a new motherboard and paying someone to install the hardware all over again.
EDIT - I use the Hyper X Cloud 3 as my headset which has a mic on it and connects via USB (not bluebooth) so not the end of the world
Using the dongle, I am currently getting 167.03 download Mbps and 26.32 upload which is pretty good right? Thank God for @ED-209 for suggesting disabling USB selective suspend from Windows power plan othersiwe I think I think I'd have lost all my hair by now.
Dude, can I humbly suggest that you slow down a bit and let us actually try to resolve each issue one-by-one?
Rushing about is just causing more expense and more frustration!
Bluetooth: this could have been addressed earlier, if you had let us know that you needed it.
not only does the motherboard not support wifi, it also doesn't support bluetooth
USB wifi sticks (at least, the cheaper ones) often only support wifi, unless otherwise specified in their description.
The PCIE cards that I've suggested to you in this thread, ALL support bluetooth, subject to having a free USB2 header on the motherboard (* see my earlier post below).
To be clear: if you decide to go this route, this is something that would need to be checked before purchase.
I have zero motherboards in my house with wifi/bluetooth, yet all of the PCs have wifi/bluetooth, thanks to a PCI-E card. This is a resolvable problem and doesn't need the PC sent back.
USB is the easiest, as mentioned ^^
PCIE is often superior in my experience, but you'd have to check there's enough space between a free PCIE slot and the graphics card. They also often need a free USB 2 header on the motherboard if bluetooth is required.
I can't see any problems with PCIE lane sharing from a brief look at the specs.
I'd suggest cards that are Intel based, since I don't have much experience with the alternatives. I have a couple of these and they work fine.
You made another thread for this issue right? How's that going?
There are lots of users of AMD cards playing WoW (I have even done so myself), so I expect this should be something we can fix.
I did call your attention to this as a potential issue in your build thread:
Can you share the link to the article itself please.
Just to clarify, main usage is MMOs and WoW specifically?
The reason I included the 7800X3D is because MMOs and especially WoW tend to like them, but if that applies to WoW classic specifically, I don't know.
The 5070, I agree that it is not the best card. £500+ for 12GB is argh, but I tend to spec nvidia for WoW because of reading a bunch of reddit posts awhile back about crashes. I think that was only with one render mode enabled and it was resolved after some time, but since I don't play WoW and this game is not included in most popular reviewers benchmarks, I'm not aware of how they perform now.
Thanks for your thorough reply and you're correct, all of these issues and solvable.
Given I use the headset listed above and it works via USB adaapter, the bluetooth 'issue' is on longer an issue.
With the wifi, like you say, can fix with a card (and I will do so) but right now the dongle is working well as a temporary measure.
So really, the only thing I need to focus on solving is WOW which I am going to go back to the drawing board on and try and find a solution.
You did indeed flag that AMD has some issues with WOW but I went for this card over the 5070 due to better performance reports, guess I was just hoping that I'd be lucky and not have any issues playing a 20 year old game with a £600 GPU :D
Also, I downloaded CSS and it runs fine.
Cool.
Alright, I thought you said that it was disconnecting or something like that? Maybe I was mixing it up with another thread.
I had a look at the thread and I don't think you have updated it yet? Let us know if you've worked through the solutions and we'll get on it.
There MUST be a lot of other AMD 9000 users in the same situation, so I'd be boggled if there isn't a fix already.
That said, is it important to mention that this is WoW classic? I don't know how much of the code base is shared between this and regular WoW, which could be an issue with both newer cards and identifying appropriate fixes?
