 - 31 Aug 2007
 - Manchester or Cleveland
I put together a pc for the first time over the weekend using the p182 SE. I was ill most of the time so I didnt do quite as good a job with it as I'd have likeed. In particular, the cable management is something that I intend to improve soon.
I'm very happy with the case. For the most part it feels very solid and well built. My only real problem was that the case door is made out of a thinner and noticably more flimsy plastic than the rest of the case. When I was manouvering the case during the build, the door moved back suddenly and one of the plastic hinges snapped right off. I managed to glue it back on, but it nevertheless still feels like a weakpoint of the case which I have to be careful with. Take it off whilst you build.
Some of the wiring was a little difficult but this was mainly due to the size and shape of the Tuniq Tower which made it slighly tricky to work around.
Anyway, on to the pics:
I'll grab some better pics of the insides when I go back to tidy the cables a bit. I think I might have made some slight changes after taking the internal pics, but its pretty close to how it all ended up.
