Good score keep pushing you'll beat mine
Result!![]()
Is that a challenge ?!
Result!![]()
It's made a big difference to Crysis. Its now more than playable on High and runs smooth as ice on Medium.
What resolution you at for that mate? I get lag when running it in high mode and prefer to play it in Medium. Oh, and are you on XP and is it at 0AA?
Sounds fine.
Result!![]()
No running Vista x86 @ 1680x1050 mate.
I used to get that lag on high with the GTS but now it seems to have gone with the GT![]()
Yes.
Damn you!
http://service.futuremark.com/compare?3dm06=3598088
I guess I could gain the extra few hundred raising my CPU a bit further but tbh I broke 13k, I will settle at that!
Strange thing I noticed too, the display adapter name is seen by riva and dxdiag etc as a GTS but the chip type is a GT - what's going on here!
I don't like you
I was on XP I'd get several hundred more points![]()
Well my card just died... after just 6 hours of use...
I'm still hoping it's my motherboard playing up as it has happened before on X1800XT as well, had to swap cards a few times for it to work.
I want to test it on another mobo just to be sure before I issue a RMA request, but I don't have another mobo to test with. Anyone from Cheltenham?
Can I claim the first person on OCUK to fry a 8800GT?![]()
Unlucky mate
