The clocks are the same regardless of what setting you use.
Jokester
Just needs a resistor solded to a pad next to the PWMIC and the other end to ground.
Jokester
Why is there no shader clock options in Rivatuner? I'm using 169.02_forceware_winxp_32bit_english_whql and riva v2.06?
Thanks in advance!![]()
Not sure if BIOS flashes are going to do anything for you, certainly the other 8800 cards just have one selectable voltage and from what I've read about the missing 3rd phase power system these cards are no different.
Jokester
Huh? thats strange I thought u could use Riva to adjust the SHaders? I'm sure I seen it there before?I think the shader can be clocked seperately under vista, in xp it just synched with the core speed (25mhz increase for every 10mhz increase in core).
Its to do with the automatic fan stuff on the 8800GT and these are the instructions its following I think, cant work out the middle three T min T range and T operating (?)
Just takes 5mins with a soldering iron.How long did that take? Looks hard.
Looks to me as if the cooler is trying to keep the core at 90C, with a 10C either side deadband, so it won't slow down or speed up the fan until it reaches 80C or 100C.
Jokester
Im running my 8800GT (XFX) with an accelero 2 - passive, although i have a 92mm vantec stealth fan mounted to the bottom off my nvidia stacker case pointing towards it about 3" away at 800rpm.
Idle - 44C - full load 58C
I have ordered a couple of sharkoon fans to mount below it, but i now can hit 14500 3dmarks, when i get the sharkoons i should be past 15k![]()
Why you able to overclock it more? I doubt an extra fan will icnrease 3dmark score.
Yeh i havent found the limits of the card yet, im a bit worried about pushing it more until the fans are in place, but it can do 730/1000 passive, which im quite stunned about.![]()
