Ah i had that problem, you just type the number straight ini am pressing enter
Does anybody know if Crucial Ballistix Tracer PC2-8500 works on this board, the website only lists PC2-6400 Crucial memory?
contents says board comes with 3dmark06 advanced....where can i find the serial number please?
theres a fix for coretemp to get it to run on vista 64Hi guys system is up and running but need some help.
Whats the best way to monitor temperature of cpu from windows? Currently on vista 64..
Thanks
EDIT: i tried coretemp 0.95 but i just get errors all the time when i try to run it
well that was too easy to be true..
set bios to manual and FSB to 400..changed nothing else ...now at 3.6Ghz....temps are 59,59,58,58 after .5hr prime 95..
would 8hrs on prime 95 useing maximum heat test be conclusive as stable?
what do i need to run to confirm everything will be rock solid.
expecting something to go pop any second.
Thanks
Install Asus PC Probe that is on the cd that came with the package.
Hi, no no no, probe is the worst program you could use to monitor your cpu temps. It will either give you higher readings than your core, or lower, depending on which bios version you have. The most trusted method is coretemp, and for vista x64 you'll need this http://forums.erodov.com/local_links.php?catid=18
Chris
