well i have the advent 9107 and as i am away from my gaming PC i did an internet search for the motherboard and found the asus one i posted, maybe that's not the one. I will have to check once i get onto my gaming PC, i may infact have 1GB DDR2 RAM.
look guys, it was not my intention to turn this into some flame war. I was just pointing out that my system can run crysis very well indeed and that people who are desperately wanting to play this game wouldn't have to buy such an expensive rig. I am away from my computer and won't be using for at least till sometime next week, but i will show you the results.
I have never used fraps, how does that work. Is that only for recording the fps? If i want to record direct source video of me playing it and accessing the game menus to show up in the video, how can i do this. Wouldn't recording the direct source of me playing the game cause a big slow down?
Oh and to anyone thinking AA is not on, it is, there are absolutely no jaggies on any objects in the game, everything is flush. When your in the jungle you can wipe out a whole bunch of trees and there is no slow down and as well each leaf you can see is AA. I have every effect on High and it works flawless.
I can tell you that depth of field is amazing, and the blur from when you move quickly, it's breathtaking. Explosions on high are all right i would like to run in ultra high settings.
So that means it's definitely running over 30 fps how much over i need to do some benchmarking of my own.
Please do not right this thread off, give me sometime and i will prove to you i am telling you guys the truth. The purpose of this thread was to know about RAM for a upgrade for crysis. At the same time i wanted to make people aware that you can run crysis on awesome graphic details on a budget system and i will prove to you all it's possible. I am sure i am getting over 30 fps because i was doing some reading reading up on different gaming sites looking at benchmarks and they all say the game still runs in 27 fps which is unplayable and i tell you when i play it's so playable that i want to play all day. So that means it's definitely running over 30 fps how much over i need to do some benchmarking of my own.
instead of flaming me, why don't you guys just tell me how i can capture direct source video of me playing it. I am running it in 1680x1050 can i actually make a video that has that resolution, so when you guys watch it, it will look on your computers like exactly how i am playing it in full screen.
Will this hinder the frame rate capturing video?
TIA
Too big to upload
Well I run with 2GB RAM and I can access 'Very High' settings. But from what I was aware of, you only need DX10 to get to 'Very High'.
