I think you're right, the hard drives are causing a lot of vibration making the droning noise on the case as it doesnt happen with the sides off.
So I'm thinking of moving my hard drives.....obviously I know I could get the Icy Dock MB-453SPF 3-Bay Internal SATA Drive Enclosure if I wan to spend near £50, but I'm just wondering as I don't have a floppy drive if I could put the 2 hard drives in the 2 floppy drive spaces or would it get a bit hot?
I'm only thinking of moving them there as the hard drive cage at the bottom seems quite flimsy as you can quite easily move it and make the vibrations worse when the PC is on.
I know people will suggest the bungee mod, but I dont have any elastic to do it
If someone could reply quickly with an opinion I would be gratful a I've got my PC in bits at the moment and a spare 1/2 hour
