I'd say PQ wise, the only real difference you are likely to notice is in viewing angles. Colour accuracy is very good from the SM245B once calibrated, and black depth is also very good (better than many VA panels even!). Image is sharp as well....viewing angles are the only real weakness in practice, especially when you use a screen of this size
Does anyone know if the 2408 will look OK next to a 2407HC? I mean does the plastic bezel and buttons look the same etc?
Are they using the same or very similar panels? In terms of viewing angles and colour reproduction?
Will you be reviewing the 2408 at TFTCentral?i believe the design is the same, and being that they are both S-PVA based they should look quite similar next to one another.
hoping toIn contact with Dell to try and arrange something, unless any kind OcUk-er can loan me theres for a bit
Just out of random interest whats your personal TFT that u use at home ?![]()
I've still got my trusty Dell 2405FPW, serves my needs perfectly well, and dont get to use it that often with all the testing of other screens tbh![]()
Anyone see this review http://monitortest.blogspot.com/ nearly as good as Baddass
Baddass, just out of curiosity, what happens to all those lovely review samples you get. Do they end up going back to the manufacturer when you're finished with them?
