Baddass do you notice the 60ms of lag on your 2405FPW ???I've still got my trusty Dell 2405FPW, serves my needs perfectly well, and dont get to use it that often with all the testing of other screens tbh![]()
still trying to sort that out sadly, they are not quite as responsive as other manufacturers!![]()
(As i dont notice it on my own 2405FPW)
Depends what you're going to be using it for. One has a minor ghosting problem (2407WFP-HC), the other (2408) has higher than average input lag. Shame really because the old 2407WFP A04 (not made anymore so hard to find new) didn't have either problem. 2408 has more inputs including HDMI and DisplayPort if that's important to you.I notice the 2407 and the 2408 are on offer this week... is the 2408 worth the £65 more than the 2407 screen? or wait for another one.
Come and gone - it's called the Dell 2407WFP A04For heaven sake is there a good monitor coming?
They hit perfection with this one. All the problems of the earlier revisions ironed out and 1:1 mapping added. They then introduced the HC version which had ghosting issues and now the 2408 has input lag problems.
If you can find an A04 2407 non-HC anywhere, grab it!
I think either would suit those uses, as would all the other 24" PVA and MVA panel screens out there. Eve/Wow aren't time criticial games really. Probably the ghosting of the 2407WFP-HX would be more noticeable, but that's just a guess, I haven't used either.being used to play games like EVE, WOW and CS2[ photoshop ] stuff. nothing much else.
Only one problem with the 2407WFP A04 if you're a graphics person, and that's the smaller gamut. Apart from that it's nigh-on perfect.Come and gone - it's called the Dell 2407WFP A04
Baddass tested it (the 2407WFP-HC) along with a bunch of other 24"ers. Around 34ms-Never seen any input lag tests done for it though. Does anyone have a link?
Hi guys, I've put together a big article about the new screen which should document all the changes, updates and all feedback about "issues" and problems which have arisen and been reported so far:
http://www.tftcentral.co.uk/articles/dell_2408wfp.htm
will update regularly as things develop, but should hopefully be a good resource to combine all the info across the web into one place![]()
