- 23 Feb 2008
I just set up mine. Wow talk about bright.Fantastic colors.Not one dead pixel mine says on it SA-LTM240M2-L01. Is it any good
I just set up mine. Wow talk about bright.Fantastic colors.Not one dead pixel mine says on it SA-LTM240M2-L01. Is it any good![]()
You are lucky!
Yours could be found in Eizo monitors, see here:
http://www.eizo.com/products/lcd/s2401w/index.asp
So what would one of those cost to buy£ 500????So what would one of those cost to buy
Only place I can find it is in the US for around $1150 so it would be £650+ here.
Isn't he a lucky b.....![]()
Now just waiting on parts for a new pc build on monday
any va panel is good mateAll come from 400quid dells (minimum) to those eizos.
No. However, you could've returned the monitor for a refund, within 7 days of purchase. You could then re-order.
I've not seen a dead pixel on this monitor, but from what I've heard, it is the size of a spec of dust. Do you not feel it would be a little pedantic to return the monitor because of a dead pixel, the size of a spec of dust?
Funny you say size of a spec of dust Sunama. Checked again when I got home from work. It was a spec of dust. Brushed it off and everything is fine now. Thanks for your inadvertent help. I agree though one dead pixel would be fine away. Was just wondering.so does this monitor only come with nice shiny panels found in stuff twice its price and them some, or is it possible to get a rotten budget panel aswell?
