- 23 Feb 2008
I just set up mine. Wow talk about bright.Fantastic colors.Not one dead pixel mine says on it SA-LTM240M2-L01. Is it any good
I just set up mine. Wow talk about bright.Fantastic colors.Not one dead pixel mine says on it SA-LTM240M2-L01. Is it any good![]()
You are lucky!
Yours could be found in Eizo monitors, see here:
http://www.eizo.com/products/lcd/s2401w/index.asp
£ 500????So what would one of those cost to buy
Only place I can find it is in the US for around $1150 so it would be £650+ here.
Isn't he a lucky b.....![]()
any va panel is good mateAll come from 400quid dells (minimum) to those eizos.
No. However, you could've returned the monitor for a refund, within 7 days of purchase. You could then re-order.
I've not seen a dead pixel on this monitor, but from what I've heard, it is the size of a spec of dust. Do you not feel it would be a little pedantic to return the monitor because of a dead pixel, the size of a spec of dust?
so does this monitor only come with nice shiny panels found in stuff twice its price and them some, or is it possible to get a rotten budget panel aswell?
