Alright, it is amazing cable tidying.
Doesn't mean the picture has to quoted three times though....
i mean this genuinely, im a noob forum user, how do i quote without including pics etc thanks in advance
setter is it ok if you can post up some more pics of the rad in the case please-thanks!
im afraid i dont have the 680i/e6600 combo anymore. and unfortunately i never took note of the settings that i had used.Sorry to go abit off subject but ive been trying to find you SETTER as im interested in your e6600 oc setting and temps as we have near enough the same rig. Is there a way you could share them with me?
sorry guys![]()
Pic's of the rad install are back on page 32, near the bottom of the Page.
Cable tidying is made easier by the fact you can hide a lot of them between the MB and rad,+ keep components to a minimum.
Right I need a vote on Red or Black for the water system.
My first choice would be black pipework with chrome/stainless steel springs over the pipework, that would look the dogs, problem is I cannot find anyone who supplies any springs like this.
Blood red would be my second choice, any one had any experience with this colour, what did you use ?.
Need to sort this out before I transfer my Quad and water cooling setup over into this case.![]()
Does anyone know of any 3 1/2" drivebay covers that are mesh/grill type efforts that will fit in the Eclipse (don't mind a bit of modding/bodging).
Like this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-101-LL&groupid=701&catid=7&subcat=1045
But for 3 1/2 bays...
looking for the same thing but for my case. now im think you could probably make your own out of a sheet of mesh (seen some at a competitor)
Like this:
Should fit.. the only problem I can see is the screw allignment on the fixing bracket might not line up.. worth giving it a go..![]()
Yeah the 5.25" ones will fit, but I need 3.5" ones.
I've ordered some mesh anyway, so i'm going to give making some a go.
It'll either work brilliantly, or fail miserably![]()
Anyone got any good tips for hiding the big bunch of cables that come from the front pannel?
Hi all,
I am hoping to buy one of these cases.
Can someone please confirm that a Tuniq Tower 120 will fit?
Thanks for your help.
