This is a TN film, not a PVA or even VA panel
That right there is your problem, send it back and get a VA like you should have...
Get it sent back Jubei - i had some marks on my second one but i put up with it as at least it was a VA
Does everyone else get this high pitched humming noise when the monitor receives no signal? ie when its in standby, if you leave it on standby the humming goes on then off due to the led flashing, but if you turn the monitor off it remains constant and becomes even louder, its very strange, im thinking of rma it but im not sure if its common with all of them, can anyone with a ocuk panel please check this, i know some people have got it but not sure if its with every panel
thanks
one question and one question only before i buy one......whats it like with team fortress 2?![]()
Anyone found a way to get by the wobble? Its getting pretty annoying![]()
Problems with the backlight perhaps? Problems persists at extreme viewing angles, so it's not that.
Although generally happy with this monitor there is one thing that bugs me.
When in the bios or a dos screen the picture doesnt fit.
Obviously this is very low res and and i would expect it to look blocky but there is no way i can find to adjust the geometry.
Are geometry adjustments avaiable when using the DVI cable ?
