Anyone able to post up their colour settings for me please? Played around with them for ages but still not managed to get a set of colours I'm happy with. I'm talking about the ones in the Nvidia control panel thingy.
I've not encountered a single problem with vista x64 relating to 32 bit apps, the most I've had to do to get something working in vista (both 32/64 bit versions) is set it to windows xp compatibility.Thank you very much.
Just one final question if I can.
I understand that certain software out there needs to be modified or re-developed if it's to make the change from XP to Vista.
Is this also the case for going from 32-bit to 64-bit?
So for example, Mr Vendor of Special Software (eg. accounting software) needs to advise his customers that their XP versions of his software won't run on Vista, they need the new Vista version of his software. Will he also need to advise similarly if his customers are using 64-bit Vista instead of 32-bit Vista. Or is it simply a case if its developed for 32-bit it'll also work on 64-bit?
Thanks!
There must be something very wrong on your set-up, my vista 64 install has gone without a single problem. Currently running the 175.12's and they are rock solid as were the previous 4 driver versions I tried.
Good luck.Must have been, it was like watching a high speed slideshow with the 174.93's. I'll reinstall with 64 bit and try thr 175.12's now
Avoid both creative options like the plague. The software DSP is a waste of money in every sense and the hardware card that goes in the express-card slot lacks the features that give the xfi its selling point. To top it off, it also suffers from shoddy drivers.what did people do about the sound option? creative or take standard option? I don't really want to buy any creative again if i can at all help it.
Other than that it's one sweet machine, the 8800's pack some punch in comparison to the 7950GTX in my old M1710Good luck.![]()
since I don't want my games being lagged/shuttering etc.Sounds good.Musta have been a bad install. Not giving me any problems this time round (except from the FPS in UT2004 dropping from 91 to 5 for no reason twice)
I'm currently running 175.16 on mine. Gives great performance for all the games I play, sli works properly and both suspend and hibernate work as well (I actually use mine on the go)with vista64, do any of you lot get any problems with:
A) any of the network/wireless issues I've heard about with vista. i.e. checking for wireless connections and therefore lagging games while they do so
B) problems with css/hl2/source etc?
I'm wanting to try and jump to vista and 64 bit OS but just abit scaredsince I don't want my games being lagged/shuttering etc.
Also, which version of vista64 and driver set seems the most stable/best performance etc?
Hi, quick question: I have a Dell XPS rucksack (old black one) that easily fits my 1730 and power brick. I'm wondering will it fit into the overhead bin of an aircraft (737)? Has anyone tried this yet? I think I'm just within the cabin allowance of 10Kilos with Ryanair!
hi
been thinking about ordering one of these bad boys, but just wondering if someone could tell me whats the machine is scoring on vista, the base score and others
cheers
adam
Excuse me if I've missed it but what colour do they come in?Can't help myself with the scorings but check out the M1730 from OcUK. We have them in stock now ready for next day shipping and you should find we're substantially cheaper than Dell.![]()
Wait and see what the Inspiron 1735 brings to the table.Good question... I wish I could have a 1530 with 1730 gfx, or a 1730 that looked like a 1530
-abc
