sounds like they realised they had a problem with all the repairs backing up and farmed it out.Interestingly, the email was sent via www.it-repair.co.uk.
not very reassuring that they can't support their own product.
I spoke to DGM CS today to enquire about my monitor and they informed me that they could not find a line of dead/stuck pixels. I was obviously puzzled so they double-checked and phoned me back confirming no fault - the representative emailed pics to corroborate this. They're sending it back Tuesday. Although I'm slightly worried that the line has disappeared, I'm happy with the service.
why would you authorise a third party to carry out all your repairs?
unless you couldn't handle the volume of repairs!
Quite a few companies do this, if your based the other side of the world and your shipping takes a month then it makes perfect sense.
... this is not using an entry level panel and this monitor has atleast has hit that but as i suggested it is probably closer to 10%!
There is absolutely no way of us to know what the failure rate is until DGM or OCUK give us the data.
Failure rate could be 0.1% or it could be 50% - we just dont have the data and this forum is not an indication as buyers will usually only post if they have a problem.
found this
dead pixels and failure rates
for entry level monitors they say 3 to 5% are returned due to failures, this is not using an entry level panel and this monitor has atleast has hit that but as i suggested it is probably closer to 10%!
You have no figures or statistics to back that up at all, it would not be worth our time selling a product with such a high failure rate as you suggest.
