any idea where i find the finger print reader software i have installed the drives but just can use it for any thing?
Not on the Cd it came with?
I'd say your sig is rather large btw
ninja or basically anyone else who installed Vistax64 on their Ultima did you install all the drivers of disk and were they fine?
Hi Ninja the stock drivers all seem fine. would like to install 177.92 with physx however cant be bothered with messing about with whql de-activation.
V1bez not sure you will get drivers from Nvidia.com try downloads on Clevo.com or if willing to mess around a bit you could try the drivers from laptopvideos2go.com....
I take it the 9300M GS 256MB is faster than the 8600M GT 256mb in the XPS range?
Anyone know by what margin?
May opt for Primo Mobile - 15.4" WXGA Laptop if this is the case!
No, the 9300 is a lot slower than the 8600. The 9300 is about the same as the 8400. The 8600 compares to the 9650.
Ok installed the updated 8.5 driver for Intel Matrix storage and sure enough Temps for hardrive have now dropped!
Idle 46C down from 50C
Peak 56C down from 64C
dont know why? but thanks Ninja
Oh by the way had to adjust the Power Options to performance to get the 29,267 in 3D Mark 2003 it was 13,500ish using Balanced which is 8600M GT DDR3 level.![]()
Hello mate, any specific one do i need to work with the laptop? I want to get the hd temp down abit, increased a fair bit with vista 64 on.
Here you go
http://downloadcenter.intel.com/fil...dows+Vista*+64&lang=eng&strOSs=150&submit=Go!
The one at the top of the page in link above
Ver 8.5.0.1032 dated 8/15/2008
