Yea but the s1 is silent
Any side by side shots.... nice build![]()
got to give the other rig to a friend next week so it will be the last chance.
Pressie for you BFG - current setup, and kitchen update!
Next to the Eclipse is an old Lian Li PC60 that I'm currently throwing a full set of Noctua's into and turning into a server. Poweredge 1400 behind, Compaq on the bottom shelf acting as current web server and old P4-2400 Dell hanging off the left-hand monitor.
Can't get a decent photo out of my SPV M600, so gonna grab a couple of handhelds from work with better pixels/lenses.
Fantastic job on your kitchen, you must have worked all hours to get it finished 10/10 M8...
Excellent setup
Looks great Tetsu. Got a golfball in the Kama?, also, not enough room to turn the Kama vertical? Just think it'll help shift any high/hot air away from the drives quicker.
One more pic before the bottom one goes.
Nice if they made the Eclipse that tall lol.You keeping them or building for friends etc...
bottom of is for a mate. He's still yet to pick it up though as he's a little scared.
Slight update with my case.
The other day when playing a couple of games noticed that the top panel was very warm. I opened her up and felt the heat which was trapped at the top.
I have a Seasonic S12 500w PSU which draws air in through the bottom and only have a couple of vents at the rear of the unit. The PSU was giving off a little of the heat but most of it was rising from the main chamber of the case. I have front and rear 120mm fans.
I decided to make a blow hole in the top of the case. I used a 120mm Antec 3 speed which is currently set to 'Low' and very quiet.
The whole case now feels much cooler. When I'm benchmarking or playing games the heat coming from the top is very warm. According to my fan/temp monitor case temps have dropped 5c.
Will upload some photos asap.
A welcome addition to this case has always been a top exhaust fan... the Akasa Omega top panel should now be included with all Eclipses...![]()
Just finished properly braiding the sata cables.
ps Tetsu what model of sharkoon silent eagle's are those, 1000 or the 2000 rpm version and what are they like for noise/cooling. Thanks.
