It wiil be a bother just in time for there new revision![]()
Exactly.
Mrk will be very happy with his "banding free" hazro until the new one is released.
Just keep pestering them for info, someone sometime will get back to you. Use webnote, email, and even research the Birmingham phonebook when you get desperate (they dont like the phonebook option).Newbie chiming in here, I've been lurking on this thread for about a month and a half though.
Bought a HZ26Wi when they were on offer, towards the end of September I think? Got the same banding issue as everyone else (This image shows it nicely) and contacted Hazro about it via their webnote thing and had Jez? phone me and say 1, possibly two weeks for the recall, since then I've heard nothing, sent them another webnote at the start of the month and emailled [email protected] (as advised in this thread) on the 14th, still nothing.
OK, the blue line is a version of green snow. It will apear in dark areas mostly where some random colors break up the darkenss. So moody games like Deadspace or Secondlife are prime targets for this blue line. It happens on the 24i too.I don't have a green snow issue with my 4870 but I do have some other interesting bugs.
Certain scenes, Crysis Warhead shows it nicely in some of the sections where it's late afternoon or early evening, the picture basically looks like a badly encoded MPEG4 file, muddy and blocky, Dead Space shows it too in certain scenes, I'm also getting a horizontal blue line about 2/5th of the way up across the screen flickering randomly but have only noticed this when playing SecondLife, so it may well just be an issue with that game and ATI cards (or it could be that on SL you have more time to take in the graphics than you do in an FPS)
As for the mounting, check that all the screws are tight. they get loose during shipping. Just be really careful not to strip it! But yeah, they stated that working with the aluminum is hard so there will not be tight seals allot of the time.The other annoying issue is that the LCD panel itself is not mounted straight, it's rotated slightly anticlockwise relative to the casing and in the botton right corner you can see the bare metal surround that attaches to the panel (I have the black version so it stands out rather a lot)
I'm still on firmware 1.0, need to get that sorted first I think. Don't really want to pay for Powerstrip. I notice ATI provide a couple of options such as "Use alternate DVI mode" and another one I can't remember the name of (not at home right now so can't check) has anyone tried these to see if they make a difference?
I think I'll let Hazro do that when they take my monitor back to do the firmware update.As for the mounting, check that all the screws are tight. they get loose during shipping. Just be really careful not to strip it! But yeah, they stated that working with the aluminum is hard so there will not be tight seals allot of the time.You're right that aluminium is a pain to work with so I'll let them strip the threads and give me a new case
Gradients aren't perfect, but I wouldn't call it a 'banding problem'. It's just the nature of seeing things in 8-bit and limitations of current processing and screen technologies. I don't think I've seen better, although I never got to see the HP. I had a close look at an iMac 24" screen which uses the same panel, and it looked almost identical in this regard.
There is a banding problem in both the 24i and 26i (which is fixed in firmware, when you get it). I know the 26i people have been waiting a long time for it but it should be coming soon.
I would call it a banding problem. Compared to the cheap nasty 1024x768 15" Samsung TFT that I got for free due to it being end of life, the Hazro looks terrible.
I posted a link to this image earlier in the thread, but I think it needs embedding here instead just to make the point
That's not due to the limitations of an 8bit display or anything of the sort.
I don't mean to sound stupid, but are you saying the Hazro uses the same screen as the iMac or the HP does? Thanks.
I was looking at monitors today and noticed how good the screen was on the iMac.
I was under the impression that the Hazro and 24" iMac used the same panel. A quick search didn't bring back a definitive answer though.
that price does look good dont it
and you dont hear of many people with issues, iv only seen around 4 in this forum....
under £700
very low ghosting/lag
large ips screen (same as used in dell 3007-hc)
only dvi connection so no multiple connection scaler hardware to cause snow/lag/banding problems that get in the way.
maybe too good to be true??![]()
