- 11 Dec 2002
- Darkest Norfolk
I would seriously go for the used one on ebay over the new one. I'm not an expert, having only owned one, but I asked around before buying it and the folks on coffeegeek.com and other forums all agree the newer models aren't as good because the grading on the little knob that adjusts the coarseness of the grind isn't as fine. In fact, in the newer models it's stepped, whereas in older ones like the one I got it's a continuous grade.
On another note, I asked this earlier in the thread but no-one was able to enlighten me: How does the Aeropress compare to a stove-top espresso pot? As strong? Less? Does it do as good a job of not letting the grounds through into your coffee?
aeropress is supposed to be pretty much espresso less the creama, however stove top does not give an espresso style coffee out - its more like a strong americano (~ 1:1 of espresso:water at a guess) the filters are supposed to be pretty good afaik, you shouldn't really get any grinds through
If no-one else is i might bid on that grinder... don't want to get in a bidding war though
		 Now that i have a proper electric burr it'll just be a kinda coffee ornament.
