From £90 to £120 that's just silly.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-AK&groupid=701&catid=7&subcat=507
I want one of these cases to replace my Coolermaster CM690, but at 120
sheets the CM690 will do..!!From £90 to £120 that's just silly.
sheets the CM690 will do..!!I want one of these cases to replace my Coolermaster CM690, but at 120sheets the CM690 will do..!!
Did you climb in her womb then?If you can find this case for £90 get it ManCuBuS, this case is like my exgirlfriend big, black & loads of room inside.
Just ordered another GTX260 so tomorrow will be SLI day for, pic's to follow.
needs a tidy up ????
eeek you should see inside my case !
Nice setup marlos, sli gtx 260 sounds very nice, btw are those vented pci slot covers your using?
Here's my creation GTX260 in SLI, need to do a bit tidy up.
Very nice build.... tempted to go SLI myself, Akasa Eclipse 62 certainly houses them well 10/10![]()
just installed 2 sticks of OCZ Reaper HPC (2x1gb) - to add to the 2x2gb already in there
it was very tight - and very hard to get them in - but working perfectly at low-ish volts at 1100 MHz - I love this RAM as it runs very cool and is very stable
Just noticed in your pic buckster, the 2 different heatsink designs on the 2 ram sets, i used to run the reaper pc6400 same as 2 of your sticks with the serrated heatspreader, recently moved to reaper 8500, which has another heatsink design.just installed 2 sticks of OCZ Reaper HPC (2x1gb) - to add to the 2x2gb already in there
