Quick question gents. I've recently begun to use the leg press (2nd time yesterday) and would like to know what others put on it compared to their squat.
I squat 110kg for 3x8, and on the press I managed 200kg for 3x8, does that ratio sound about right?
Nate
yep, sounds rite. I can get similar proportions, a bit less weight tho.
this does depends however on the angle of the press. the bigger the angle, the more you lift.
By the bigger angle, do you mean negative? so your effectively below the weight, pushing it upwards? Thinking about it, you cant really push weight down![]()
Yes you can, 1 example.... tricep PUSHDOWNs ;]
The bars being pushed down, and the weights being lifted UP by the series of cables, no? A pushdown is more or less the same thing as lying on a bench with a barbell and pushing it towards the ceiling, pivoting at the elbows, the same for french press. Pushdowns with ropes, bars and handles surely is just this standing. I think what im trying to say is weight is either pushed or pulled up?
Awaiting correction![]()
Well..the weight is moving in an upwards motion yes....But to get it up you have to push 'down' theoretically.
yeah, so technically your pushing the weight up, well the bar down and the weight moves up. Pushing weight down wouldn't be beneficial because of mavity and if the weight could be pushed down it'd already be on the floor? Don't know if that makes sense but hopefully someone can see what im getting at!
If not we'll have to agree to disagree!![]()
Still, the pec deck is an abomination of a machine :/
so what's best:
30kg dumbell press
or
80kg smith?
