i guess the chase to find a panel like i had in my old DGM is over - it's never going to happen
got anything in mind?
If you saw a "pink tint" only in gaming mode then that's NOT the green/pink tint issue people are complaining about on this thread. That's a separate uniformity issue which causes things like white backgrounds to appear very uneven in colour.. green on one side pink on the other etc.then this had a great panel but the pink tinting was really bad in gaming mode.
What are you talking about. HDMI can carry 4096×2160p24.
Ta. I didn't know that. Hopefully the hdmi repeater on my amp will handle a 1920x1200 signal.
http://www.sony.co.uk/product/hcs-cinema-surround-kit/ht-ss1300#pageType=TechnicalSpecs
how annoying, OCUK were going to ship out my replacement tomorrow but they've gone out of stock.
If it's only in gaming mode then what you're actually complaining about is a wide gamut issue. This monitor has a very wide gamut
If it's only in gaming mode then what you're actually complaining about is a wide gamut issue. This monitor has a very wide gamut - It can produce reds and greens far more vivid than an ordinary monitor. This is great, except most content is created in a standard RGB colour space and, until the day Windows implements an automatically colour managed desktop and Direct X, you're going to experience colours which look more red and green than they otherwise should in game mode, as that bypasses most image processing to reduce input lag.
You'll experience this with every single LCD monitor that has a greater gamut than standard sRGB, and that's going to happen more and more.. So hopefully Microsoft will do something more soon.
In the 360 you can't do anything unless the game developer added an option to compensate for wide gamut displays. On the Mac, the U2410 has a specific Gamma mode for using the Mac, although I think the new Snow Leopard release finally switches the expected default to 2.22 like everyone else uses. Anyway, the Mac has the same issue as Windows, but I'm pretty sure Safari is a colour managed application, so that should actually be free of the wide gamut issue.But what about people that don't use Windows? I use a Mac, Windows and a 360 so the pink tint is a large problem for me.
It's something that'll be dealt with over the coming years. Basically newer screens can produce a wider range of colours than the old types, and right now we're in a transition zone where that's not always a good thing
 crap but least it will be worth it!
 crap but least it will be worth it! 4 monitors, 1 with dead red pixel, 1 with green lit, 1 with massive tint issues, 1 with milder tint issues. Is it too much to ask for a U2410 without dead pixels and free of noticeable tint? Right now it appears my answer is yes
 4 monitors, 1 with dead red pixel, 1 with green lit, 1 with massive tint issues, 1 with milder tint issues. Is it too much to ask for a U2410 without dead pixels and free of noticeable tint? Right now it appears my answer is yes  Worse, the Adobe/SRGB black level bug would require yet another screen exchange, which I personally wouldn't be prepared to do given the apparent dificulty of getting a panel without one issue or the other.
Well, a replacement arrived from Dell - completely free of the tint issue!
So, problem solved, or it would be if it didn't have a lit green pixel on the bottom left.
 Time to give up, or will you go for #5? Will Dell keep replacing these screens ad infinitum?
 Time to give up, or will you go for #5? Will Dell keep replacing these screens ad infinitum?By the looks of things they just keep re-sending them out until someone accepts one..Yes Mkay! Dell are completely mad. A simple check on the production line for lit pixels and tint would save them a lot of money. What I want to know is if Dell then send them on to LG (panel manufacturer) for a refund?
No. There's a 30 day period where they will exchange for new. This, depending on the speed of turnaround, gives them about 4 chances to get it right before someone will likely eventually inform you that your expectations are above what they can deliver. I also returned the original for a refund, so technically this was chance number 2. This time the customer service guy was less pleasant than usual, but volunteered to send a replacement before I had a chance to fully think about it. This is genuinely the last chance though as it's more annoyance than I need.Oh.Time to give up, or will you go for #5? Will Dell keep replacing these screens ad infinitum?
They tend to automatically offer this during the first 30 days.Alright, gonna give dell a call for a replacement. Btw MKay, Did you asked for a brand new sealed replacement?
The previous 2 tinted monitors were from the July batch, and this tint free (but with lit pixel) is from August.
