- 5 Jun 2003
- Falling...
I once believed that straps are no good but when I came to understand kenisology a little better I realised that it was better to utilise the muscled being exercised properly by beig able to use them for reps than drop the weight and not progress. Remember using straps doesn't stop you from performing the exercise. In deadlift it's a leg and back movement using straps won't impare it, BORS are a back and shoulder movement it won't affect your back and shoulders. In fact it can enhance the effect of the exercise by helping you concentrate on good lifting and ROM.
