- 7 Mar 2005
- LU7
Possibly not the best question since anywhere that would sell an NC10 would likely be an OcUK competitor.For new buyers, where can we get it with W7?
Does anyone know if you can alter the brightness for the webcam?
I got all the above drivers installed, its just web cam always comes up a little dark.
Any ideas?
Does anyone know if this is possible?
EDIT
After a lot of searching around I found the software for the cam that gives you all the brightness/colour + lots more. Works good in W7.
Do you guys find these laptops adequate for web design?
I have my old shuttle that was top stuff back in the day! (3ghz p4, 1gb ram, 9800pro running off my 32" hd screen, only 720 resolution.
Would these run dreamweaver, fireworks, firefox okay?
The reason i ask is because i'm really getting into web design and want to get rid of the shuttle and use the laptop primarily.
fleabay?
There's no UK layout ones on there (from what I can see).
You can buy UK keyboards from here http://www.laptopbits.co.uk/Database_files/Samsung_NC10_Spare_Parts.htm but its 70 quid.
I'm tempted just to buy a US one for ~£20
I have a retail copy of w7, another laptop with a dvd drive and a usb stick. Is it possible to create a bootable usb to install on my nc10?
be keen to here the answers to this one![]()
