Quick review of the Fat Gripz for those that were interested.
Shoulders & Arm tripple superset.
Standing Overhead Press W/FG:
50KG x 5 x5 - 60 second rests.
Didn't feel to much harder although I was focusing on my grip. Grip was tested when lowering the weight in a 'power clean' fashion. Also power cleaned up which was a little more challenging than usually with a bit more wrist involvement.
Seated DB Shoulder Press. No Backrest. Palms Facing. W/FG:
18KG x 10
18KG x 10
18KG x 9
Really liked doing palms facing, this was the first time. FG's made it quite tough, bit of forearm wobble.
Side Raises. Alternating. W/FG:
5KG x 10/10 x 3
I don't do these very heavy but fight the negative like a mo-fo. Again not too tough but grip was tested.
Cable Face Pulls:
41KG x 10 x 3
Tried using the FG's on the ropes but it was very akward and uncomfortable as my wrists were at the wrong angle. Don't think they can be used for this unless using handles which I will try next time.
Standing Alternating Arnies. W/FG:
18KG x 8/8 x 2
Ditto for seated DB Shoulder press.
BB Shrugs W/FG:
60KG x 10
80KG x 10 - I made 3 and then had to take them off! Insane how much harder it is to grip when your hands are half open.
100KG x 10
80KG x 10
60KG x 10
EZ-Bar Bicep/Tricep Tripple Superset. W/FG:
22.5KG. Bicep Curl x 10, Lying Skull Crusher x 10, repeat twice more then rest.
This was REALLY tough. Not on my arms but on my forearms. It absoultley ******* killed. I had huuuuuge pump. So much so that I couldn't actually wiggle my fingers. They were almost frozen in the shape of the Fat Gripz. It was very difficult to open/close my hand. I even struggled to push the 'Home' button on my iPhone
(seriously).
I needed to do this again got to the end of the second sub-set of bicep curls and had to give up, it was just too intense.
I tried some 30KG overhead press and my forearms felt very tight. Was more of a warmdown for 15 reps but I was very aware of how pumped my forearms where.
Normally I'm good to hold around 130KG in a false grip for a few reps and then need to strap up for shrugs. Seems the FG's took it out of me. My traps were also killing from my back and leg workouts so didn't want to over do it as they were quite sore.
I normally get quite a good forearms pump and generally can still crack on however this really did stop me doing anything for about 3/4 minutes while serious build up of lactic acid cleared.
Forearm measurement with arm fully extended, back of the hand facing down and wrist tipped towards me usually measured around 12.5". 20 minutes later when I got home I measured just over 13".
I am now refering to these as 'blue ********'s'
Edit: I did find these recruiting more bicep even at this light weight. I'll try some heavier curls when I start my new routine as I won't be trying a tripple superset so can bang some more weight on.
