It's actually not that laughable...!
Remember who made the standard F1 ecu![]()
Ferrari? Oh wait can't use that one. Damn
). Not to be sniffed at IMO.
So it looks like Hamilton is claiming that RedBull have the fastest car, by far.
http://news.bbc.co.uk/sport1/hi/motorsport/formula_one/8579797.stm
Obviously we need to see how RedBull go in Australia, as basing performance on a single race could be premature.
What I want to see now, is how Alonso/Ferrari go at Australia, as they will be the ones to take the fight to RedBull, if RedBull emerge as having "the best car, by far". I know CSl is VERY confident that RedBull have the best car, but we need to see how they go at Australia.
The one thing that should give Ferrari confidence is that Alonso was able to produce a race lap which was over a second faster than anyone elses.
Right now, the only thing going for McLaren, is the fact that they have Hamilton and after 2009, they have shown they know how to turn a bad car into a race winning one.
So, at this stage, the 3 leading teams all have something positive to cling to.
What I like about RedBull is that they have shown that they are not 1 hit wonders (like BrawnGP) and have been able to continue 2010, where they left off in 2009.
I believe that when reliability is brought into the equation, Ferrari have the best car.
I think its a reasonable theory.
Ron is saying that the ECU may have (been instructed to?) shut down one of the cylinders to save fuel. Apparently a feature of the McLaren ECU (which all teams use). If anyone should know.. it would be Ron.
It is strange that apparently a spark plug failed but that there was no consequences of fuel getting injected and not burnt? Surely that should have cause loads of flames out of the exhaust? Or I suppose the ECU may have detected repeated non-sparks and stopped injecting fuel on that cylinder?
His words "Ron is talking out of his *** and clutching at straws"Err what?I believe that when reliability is brought into the equation, Ferrari have the best car.
Of all the front runners, theirs is probably the least reliable!!!You must have missed the bit where ferrari changed both engines prior to the start of the race ...
and had to back off behind another car due to heat worries, even in clean air massa had to back right out.
Err what?Of all the front runners, theirs is probably the least reliable!!!
Their testing was fine, admittedly, but that doesn't really prove much.
Both Ferraris and both McLarens finished the race without mechanical issues (which actually caused their race to be compromised).
RBR spark plug died. That's the official line from RBR, so we have to assume it is true. This is hardly the fault of anyone except the QA department of the spark plug manufacturer.Both Ferraris and both McLarens finished the race without mechanical issues (which actually caused their race to be compromised).
But why would Vettel/RedBull go through that pullava? They have nothing gain/lose by saying the problem was a spark plug or low fuel. The result stands and it wouldnt make any difference to the points standings for the actual for Vettel losing speed.
spoke to CH about this today over a cuppaHis words "Ron is talking out of his *** and clutching at straws"
PS: Those two suspect engines that Ferrari swapped out could, yet, prove to cost them this championship. We will have to wait and see.
Alonso went on to push his car even harder and posted the fastest lap. After which, he finished the race....with no mechanical problems..
Redbull have a lot to lose i.e teams now know how far and how fast the car will go before running out of fuel by
just by looking at the lap times before and after the problem.
Well he did the last few laps ok but pulled up after the finish line.
Which says to me that they was running out of fuel and as you know there has to be 1ltr( I think) left in the fuel tank
at the end of the race or your disqualified.
RE: Overheating...
I would imagine the cars are designed to make best use of clean air when running on a clean track, and are designed to cope in those situations perfectly (even in bahrain's heat). However, when in hot disrupted air from another car they would expect to see overheating after an extended period of time in such a hot environment.
Its hardly a reliability issue, its facing reality/physics!
