well heres mine got it set up last night (took a while because of the PSU)
I'm sure it will, but an 8800GTX fits in this case doesn't it? Just checking as might get this case soon. Looks very decent.
The only thing I could suggest that could be improved about this case is the space behind the motherboard tray. To get the back cover on without bulges you need to really have the cables very neat!
Did you need an extension on the cable from the PSU to go round the back of the mbd, or did it reach on its own? I have that corsair psu myself (the 620w version), and am looking at getting this case, so would like to know if I need to get an extension or not.Here my setup:
I used cable tie bases, can't see any on OCUK, but you can get them from several places that I can't mention on this forum. They have an adhesive base and you thread the cable tie through them enabling you to secure the cables tightly to the rear of the MB tray. I had no trouble fitting the rear panel after using them.
any comments on the smell?
Currently sitting in my basket with a new PSU and a few fans.. are the fractal fans any good?
