comes with 2x 120mm. Gonna grab a few 140mm with the case... just need to get paid now I thinkSo whats the general consensus on extra fans?
Are people generally buying 2x140mm Fractals? Where are they fitting them? What does the case come supplied with?
any comments on the smell?
I used cable tie bases, can't see any on OCUK, but you can get them from several places that I can't mention on this forum. They have an adhesive base and you thread the cable tie through them enabling you to secure the cables tightly to the rear of the MB tray. I had no trouble fitting the rear panel after using them.
You can see them here in one of my Pics:
http://forums.overclockers.co.uk/showthread.php?t=18122288
i am planning to buy some cable ties & cable tie bases, what size cable ties and bases did you use?
