Working perfectly - Instructions HERE Hope this helps.Someone point me in the direction of the "speech to text" thing ??
Just received mine - its charging at the moment![]()
Had mine a week today and a great phone even flashed it with the Generic rom and have updated it now OTA, something i couldn't do on the stock T-Mobile one.
Where did you order yours from?
If you use the "backup to SD" feature, what is "lost" if you put the genric ROM on... Also is it network unlocked if you do this ??
It works well enough for me for it to be useful. The processing time is fairly quick while wi-fi connected. Not so good over 3G.I don't know all the excitement over speech to text i tried it on my old phone the Milestone and it was rubbish, doesn't get all the words right and takes far too long to process it.
You lose everything which didn't bother me its just like setting up the phone again, it will still be network locked i imagine but just means you are using the Generic rom which means you will get updates faster as they direct from HTC.
If is a gamble as if it broke your phone it might be hard to get it changed by T-Mobile so using roms is all at the users own risk.
I used the two links on the second page. One was from megaupload.com and the other was 4shared.com.Sinopa - Imissed your post about the "voice to text". Did you use the link at the bottom of that thread or the one on the first post which has since been removed ??
got my phone friday morning been playing with it since. one thing and yes im an idiot but i have lost the clock weather thing off the screen how do i get it back on?
"text to speech" + "recognizer not present"Last thing... I installed the "text to speech" app under the settings menu but cant find anything its used for. Tried Handcent but it says "recognizer not present"![]()
People say long charges but when mine was full it stopped charging so what's the point of charging it for long periods.
Are you confusing text to speech with speech to text?
