Khaaaaaaaaaaan! has emailed be back.
Might ring them up myself now.![]()
Haha quality
Cost of phone?
Anyone elses Desire rattle around the 3.5mm socket area? Another chap on the AV forums mentioned it intially which got me thinking if anyone else has this... don't know if this would qualify for a replacement though?
Khaaaaaaaaaaan! has emailed be back.![]()
W.T.F
I told him about the offer via trust and he gets contacted before me.
Off to harrass Vodafone via e-mail!!!1
apparently that was the best I could get via T-Mobile upgrade.
Hi,
Got my Desire on tuesday, loving it so far - cracking service from Vodafone too, upgraded me 5 months early at no cost
One issue I'm having is the battery life - I'm barely getting a day's usage from it - that's with mixed use, texts/emails, couple of calls, maybe a little bit of web browsing - is there anything else I can do to lengthen battery life? I'm using Advanced Task Killer to cut off all the apps i'm not using.
Ta![]()
May improve after a few full discharge - recharge cycles, but im getting about the same, had my desire since end of march.
), i ordered from the famous site begining with p
it's £4.99 on there compared the £10 something after delivery on the htc site(and most other sites).just waiting on the screen protector, case and desk cradle(appetently comes with an extra battery free) to be delivered. still thinking on what to do about the car charger, with the extra battery should be ok on most occassions but might be a time when both are low/dead.
Which cradle did you buy? I'm looking for one that'll also charge my secondary battery as well as the handset, but can't find anything in stock.
I don't know how it happened but when I came to ring my mum about 4pm I found that the favourite contacts thing on the screen to the right of the main home screen was gone, it was there this morning when I used it this morning about 9.45am. any ideas how I re-add it?
anyone know the difference between a micro sd class 6 and a micro sdhc class 2? any idea which performs better?
Wiki said:The following are the ratings of some currently available cards:
Class 2: 16 Mbit/s (2 MByte/s)
Class 4: 32 Mbit/s (4 MByte/s)
Class 6: 48 Mbit/s (6 MByte/s)
Class 10: 80 Mbit/s (10 MByte/s)
