upping the multipler shouldnt damage the cpu ... just make the system unbootable without a BIOS reset ??? I stand to be corrected on that one though
upping the volts is what would kill a cpu if you go too far .. like shoving a car cigarette lighter into your mains socket @ 240v ..
at the mo the cpu is happy on stock volts at 3.8Ghz doing prime95 (64bit version if that makes a diff) but as a relative noob at clocking I dont know how long to leave it before assuming its stable 24/7
Cozzy
EDIT UPDATE : OK we have a failure on 2 cores after 10 mins or so after upping the Multipler to 19X on stock volts
Cozzy
