Most people move the rear 120mm fan to the front so there are 2 at front and add additional fans to roof, but since you won't be adding more fans it would be better to move the rear 120mm as an exhaust on the roof (blowing upwards), and leave a single 120mm at the front.I just got the Fractal and it really is a nice case but I need some advice.
I also got the Corsair H50 CPU water cooler and I understand its suppose to go where the back stock fan is.
If I take the rear stock fan, where do I place it? And whilst were on this subject, should I move the front one?
I don't think I will be buying anymore fans btw...
Also, the fractal fans... With the fractal sticker showing, is it pushing or pulling air?
I really like the look of this case, and after reading practically the entirety of this thread this weekend I think I shall be purchasing it from Overclockers in the next few days! With a few extra fans, of course...
I'm really anti-LED and so hate all these new Antec, CoolerMaster etc cases that are coming out in recent years with blue and red lights all over them. I think they just look extremely tacky. The Fractal R2 just looks very classy (to my mind, at least) and has plenty of space for my crossfired 5850s! Perfect!
, i bought 1 of these handy dustcovers for the side fan which i recomend (although not cheap) http://www.overclockers.co.uk/showproduct.php?prodid=CM-086-OK
i just put a side fan on mine for gfx cooling, id advise you do the same with CF cards + summer, i bought 1 of these handy dustcovers for the side fan which i recomend (although not cheap) http://www.overclockers.co.uk/showproduct.php?prodid=CM-086-OK
would be nice if they even slightly mentioned the reason for B Grade on the product
Should be interesting carrying it home from work on the bus
