Caporegime
- 13 May 2003
- Warwickshire
Never mind.
Don't sulk, just post a smaller pic!
Never mind.
Thanks, and yeah that's exactly what I do. I just want size and strenght while being fairly lean.Compared to where you were you've definitely added mass. And still pretty lean, so keep it up - good work mate.
What are you after? General more size?
Just keep focusing on the big compound lifts, shoulder and back work will really help build some size. Also I trust you're doing some serious leg work too?
I feel your pain buddy. Have you measured yourself around your shoulders, overarm measurement? i.e. around your whole body not inside the armpits. That's a good indication for clothes measurements as it takes into consideration shoulder size, as well as back and chest thickness. I consider anything 50"+ to be well on your way to the world of hench.![]()
Trousers are ridiculous to get right - I can't buy anything off the net unless I know the supplier! I don't like skin tight clothing at all, let alone trousers, but I hate baggy stuff... rock and hard place!![]()
I agree about the chest and yeah I'd like the abs to be a bit more visible. Not a huge fan of really defined abs lol.Needs more chest development IMO, and his abs seem small for his bodyfat. Might just be the light though.
Yes I have backed my stuff up. It's only a speaker problem anyway.You don't backup? And even if you don't surely you would have before sending your laptop back to the manufacturer?
Haha yepI don’t like to show off personal tattoos, although it is small I still keep it to myself and GF, sad I know.
What happens if you're on a beach?
Wow, his transformation is pretty crazy! I won't be taking any of that crap though.
I'm assuming with hard work and determination, it's pretty damn possible to get to his level within a year or two?
Points his finger at everyone and says divert your eye you ******* spook.
Or puts a little piece of duct tape over it.
