50 a week? Good luck with that!
Depends what you're looking for. For at least a while you should be looking for jobs in your sector of which you'll probably be able to find a max of 5 a week. Once you actually put some effort in to tailor each Covering letter etc. those 5 would be a full time job in themselves. A couple of thought out applications a week would be easily acceptable.
On the other hand if you're just looking for a dead end shelf stacking job then 10 a week would probably be a limit (unless you're just handing out CV's).
In the 6 months I was actively searching full time I probably applied for around 25 proper graduate jobs in the area I wanted to work and got 3 interviews. That was almost full time searching (4-6 hours a day, 6-7 days a week when searching, researching and writing cover letters are all included). I then got a christmas temp job and my job application number dropped massively as I didn't have time search and send that many any more. That temping destroyed my will to search for proper jobs and I ended up looking and applying for a proper job every few weeks after I left...
Either way if he puts one thing down a week he'll still get JSA...
