Makes no difference , debug mode if anything should be on
ahh handy to know
What bug i just put loads of stuff back on mine to see how this new rom goes.
Meh i get write protect now on my external sd card lol, can't add anything to it although stuff i added before is there, this what you mean ?.
not sure what to suggest , maybe try different google searches , not much help I know , but that's how I worked out how to solve my problem
i sometimes get the H symbol so why do i get a network connection error when trying to search for apps ? annoying.....
Try turning it off maybe?I have only ever got that error on wifi, never on 3G/HTry turning it off maybe?
Yeah it works, you have to create the APN's yourself is all.From what I can see some of you have got this phone working on three but have had problems with setting up MMS and internet browsing. Does this phone work on three at the moment? Is it easy to set up? What will I need to do?
It is unlocked, but has the O2 lock screen and firmware. Its not on their website, ring your local store to see if they have any. Got mine for £319 + £10 topup.Also whats the best way of buying the phone, given that I want to use my existing plan, I've seen a number of you mention buying it on pay as you go on O2 I for around £300 and the phone is already unlocked? Is this deal still out there? It doesn't appear to be on their website.
Hi, thanks for the reply, is this straight forward? I assume it involves entering a server name and user name and password? Something like that? Is this information readily available?
So the phone itself is unlocked and not branded, but the screen saver is branded? Can this be changed? How does the o2 firmware differ from others? Will it be limiting in any way?
Thanks again
