Caporegime
- 1 Mar 2008
People are saying you need to use your Goldcard when updating if your handset is debranded.
Testing this theory now.
Bit late for me now!People are saying you need to use your Goldcard when updating if your handset is debranded.
Right so I switched my Orange image to a stock one. That's all I want out of it really.
To do this, I followed the steps at the bottom of the first link below (how to unroot your HTC Desire to stock), which included setting up a gold card, which is the second link below. The third link is the list of official, untouched images (I used RUU_Bravo_HTC_Europe_1.15.405.3_Radio_32.30.00.28U _4.05.00.11_release_121865, apparently there's a problem with locked orange phones and you should use a 1.15 rom like this one and not a newer 1.21 or you'll lose the ability to make calls). It was really easy.
http://forum.xda-developers.com/showpost.php?p=6710092&postcount=4
http://android.modaco.com/content/general-discussion/305672/creating-a-goldcard/
http://forum.xda-developers.com/showthread.php?t=695667
Yeah peeps, custom icons are being used with LauncherPro2nd dock is a smartshortcuts menu with cam apps menu window, media menu window etc.
Pic:
http://robbiekhan.co.uk/root/android/desktops/sunset_th.png[img][/url]
OD 3.0.2 patchfix is now live BTW, adblocking isn't working on 301, testing 302 now![/QUOTE]
Khaaan, how'd you manage to get the transparent Facebook and Twitter widgets? I've downloaded two .apks for them, but they won't install, and I can't uninstall the two system applications to be able to replace them.
glad i didnt go with the update!
hboot 0.75 goodness here
http://forum.xda-developers.com/showthread.php?t=741672
I have an orange branded desire.
I have followed this: http://android.modaco.com/content/general-discussion/305672/creating-a-goldcard/ and tried to install this: RUU_Bravo_HTC_Europe_1.15.405.3_Radio_32.30.00.28U _4.05.00.11_release_121865.
I get the 171 error and then if i try and reinstall it i get 131. Any ideas?
EDIT: Do i have to unroot the phone or does the install of the rom do this?
