You can run BOINC as a service on W7, but I assume it interferes with GPU usage (works just fine with CPU). Thanks for the tip-off (I have a W7 license for the PC that's doing MW, but I haven't got around to installing it yet).
Yeah, on the boinc install it gives you the option to run as a service, but you cant do any gpu crunching if you do, you get a warning stating something to that effect if I remember rightly..
Did you have any joy researching that mobo of yours Mr Edge?
I'v ebeen browsing since earlier and still no nearer on deciding what i want![]()
but with 4 x 480 in it restarts after 30 mins-1 hr, everyone is telling me my powersupply is not upto it Thermaltake 1500w toughpower, i thought it would have been plenty .....do you think they are right if so i am snookered and will have to go 470 and hope that cures it?
Thank you sah!![]()
Toxic, why don't you swap the 480's into your other setup, doesn't that have the same PSU? At least that way, you'd get an idea if it were really the PSU or not....
I'd say not enough power.
Furmark tests at stock will pull just under 1500W
Thats why I went with 470's, you probably need one of these: http://www.thermaltakeusa.com/Product.aspx?C=1265&ID=1544
Nice bit of shopping there Mr Biffa, a thermaltake too you know what i like lol.
Been to town today and cannot find a kill-a-watt meter but will give B&Q a try at the weekend. I wouldnt mind ordering that thermaltake but by the time i pay shipping and what not i might just say to heck with it and ditch the 480's in favour of 470's and clock the nuts off em.
Shouldn't imagine having a power problem with 4 x 470 if i do there'll be the biggest hissy fit in TBag history
Well with Mr Halz,Loudbob,Marine,Biffa,Tbag and potentially Mr Area51 about to upgrade i would say the autumn upgrade program is officially up and running
OOps and one more too who cannot be named untill the weekend![]()
Mr Marine - that was a bit sneaky......2 of them? (http://setiathome.berkeley.edu/hosts_user.php?userid=9145696)
Hope things don't get too hot for you - must be quite noisy!
I might have to accelerate THE PLAN!
I wish I was running 2 of them but Borkley sees my GTX260 as another 470 for some reason
but not to worry another will pop in at some point
