- 25 Sep 2008
- Orsett, Essex
can't do Sunday - working - Nuclear Submarines don't build themselves y'know.
Not yet they don't
Ah yes....
I have secured transport for either Friday or Saturday (can't do Sunday - working - Nuclear Submarines don't build themselves y'know).
So, which ever is convenient?
Not yet they don't![]()
Either is fine Mr Loudbob sah when i comes to transactionsTBag Towers is a 24-7 thing really anytime day or night is good.
Dont be silly Mr Marine he's not talking real nuclear submarines he's on about the big cardboard ones, like the ones they use in old james bond movies![]()
At least that 1 seems OK (famous last words)!
Something's in the air!
Been having random unexplained shutdowns since last night. Still haven't found the cause for sure, but I'm now down to 1 GPUAt least that 1 seems OK (famous last words)!
So, my upgrade may turn into a replacement. Might be able to get the wc onto my 1 remaining GPU next week. Once I've done that, I'll refit the 'suspect' card, and see if its still a goer since my problem may be Motherboard heat related.
Mr Marine - I might be any easy stomp for you. Can't afford the replacement for a little while yet, so my RAC will fall back to 18-20k![]()
Great, will try and make it Friday (will let you know for sure).
T'is true - just google 'HMS Astute'
Hows the car coming on Mr M?
Hopefully you can fix the gpu or it may right itself, either way hope its gets sorted and fingers crossed you have warranty on it![]()
OK got a few more non-shiny bits turned up today hopefully my turbo will now work properly after they are fitted and it will be ready to unleash on the road with its awesome oldness![]()
So, can I get me green juice organised and installed before Marine starts breathing down my neck? Will the 'dodgy' card turn out to be runner? Have I got enough good slots? Which slots are good? Will my wc turn into a green stain on my bedroom ceiling? Tune in next time for another exciting episode of:
'Guess why my RAC's gone through the floor'!
) otherwise I would have another 470 in here and bin the 260
1/5th scale buggy!!! Is it in show us your motor thread?
Wanna see wanna see
**quick question** minimum psu requirements to run a q6600/crapish board and 2 x 470? Found a calculator online but it dont work![]()
I'll be round your way tomorrow - will be bringing the Stacker
Should be setting off around 2.00pm - expect arrival around 4.30pm depending on traffic![]()
Bring something to protect your head as I have asked toxic to give you a slap for the stomp last week![]()
Blimey Loudbob i'd better do it too or he's threatened to slap me when he's up this way if i dont
