No, but you can buy the Plus version of Laucher Pro to get widgets for $2.99 which are very similarIs there a way of getting the HTC Sense widgets working on Launcher Pro, I want the Laucher Pro dock with Sense widgets.
I've not long received my Desire from O2 as an upgrade.
Should I bother debranding it etc, and putting 2.2 on, or just play it safe and wait?
Is it really easy to do?
It'll say amoled on the box if it has, if it's slcd it'll say nothing. I've got an slcd and think it's fine.
Thanks if its as simple as that then; all mine says is 3.7inch touch screen on the box so I guess its SLCD then
Adobe Flash Player 10.1 version 10.1.92.10 is now on the market
