- 31 Aug 2009
- Surrey, UK
No love for a 5770?
I've got it working, running it at 5760x1200, it works very well, removes most jaggies.Changed the files and i'm able to enable option on 5870, started up Fallout New Vegas but after loading save up screen is blank but I can hear gun shooting with it enabled. Running eyefinity on 6144 * 1152 res so that might be something to do with the problem. Anyone else managed to get this working on the new Fallout ?
Just quickly tested it on Bad Company 2 on my 5850. It seems to improve the image quality - eliminating those pesky jaggies on most surfaces. There are still issues on some surfaces but overall an improvement. The game also runs as smoothly as ever (I didn't record the actual framerate though). It could just be the new graphics driver that is improving things though. Who knows?
Out of curiosity what mode should you select after ticking the 'morphological AA' checkbox? Box is the default AA mode but should you use edge-detect or what?
According to this the filter doesn't work with Bad Company 2 anyway - http://www.tomshardware.co.uk/radeon-hd-6870-radeon-hd-6850-barts,review-32028-4.html
Again, ccc gives too many options.... what to choose.
