I just wish it was one which vastly improved the IQ.![]()
That depends which way you look at it bud. For games where there is no way to force AA, or games where the performance hit with traditional AA is just too big, then it certainly improves the IQ.
Then you'd be pleased to know that there won't be a game where you won't be able to whore it up!![]()
i've done the mod and the options are in CCC but i can't see any different from no AA to MLAA. it's either not working or i'm doing something wrong.Yes, catylist maker has already said in a later catylist releae possibly 10.11s.
there are ways to enable it unofficially though![]()
That kills my fps down to 0-5 fps.i had to force 4x edge AA for it to work, but it definitely does work. it works with me1 as well.
You will need to reboot.when i do the mod i don't even have AA options in CCC![]()
SSAA x8 which seems to remove more of the jaggies runs at around 20-30 fps.
there are a few instances where it doesnt apply to some dx 11 or dx10 games. those are specifically down to the type of AA they use ect.
i did, no change...
It works fairly well in GTAVI, didn't really notice any performance hit and does look allot better than no AA at all.![]()
Maybe people are forgetting to change from "standard" to "edge-detect"
Let's step back a bit... The idea is for MAA to work even if antialiasing is disabled (i.e. set to 'application' with no AA set in the application itself). In this case the AA sample type is ignored so setting it to edge-detect won't dictate whether or not it works. It just seems that the filter, at the moment, does not work with every title.
