True - Evernight has a lot of RP playyers but they talk in l33t speak and are 15 years old.
Hehehe, not quite my demographic then
Try the turbineinvoker.exe see if that gets you going.
Yeah I tried that after the launcher.exe one didnt work. Does the same thing, spazzes out on the turbinelauncher.exe file.
could always replace it with the one from your backup folder ? I know others with the same error code as you who are trying to fix it .. Ill let you know if it works.
I could try sending you my TurbineLauncher.exe if you want.
Thanks but my launcher doesnt even get to the updating part anymore, just hangs on "Opening Main Form" now, so not sure that the launcher will help now.
it seems those who didnt try the preview client dont get the error ?
