Caporegime
- 21 Jun 2006
Ive been stuck on the same weight for the barbell bench press for about over a month now any ideas how to get it to go up? My DB bench press slowly goes up along with other chest exercises, but just not that one.
The same has happened to me. My 1RM for flat bb bench has been the same for almost a year now, whereas my incline and decline dumbbell presses are both going up steadily. Doesn't make any sense!
what weight are you guys stuck on?
bakes - lower it by 5kg and do 5 sets of 5 reps with 90 second breaks.
mansize - lower it by 10kg and do 5 sets of 5 reps with 90 second breaks.
if you cant do a full 5,5,5,5,5 and end up with 5,5,4,4,3. that means the weight is too high for you. thats why your not progressing. lower the weight and start again.
if you can do the full 5 sets of 5 with 90 second breaks, try your limit again after at least 2 days of rest, you should be able to break it, if not then you have hit a plateau. use a smith machine or leverage machine for a month or two in order to break through this limit.
This is my 2nd week of having to do Mon, Tues, Wed and Thurs as I've been busy on Fri eve and the weekend. But now I've really run out of steam, still been having back DOMs which affected my shoulder workout yesterday, didn't lift as heavy as I did the week before, which sucked a bit.
). If I can do a working set at 145x5rep max how should I pyramid up to a 1 rep max?
