If I say yes is this where you say that the first one is a 14 year old Cambodian boy?
Looking forward to the session on Sunday, I'm just hoping that my leg starts playing the game again and stops being sore.
Do they put something in the water round your way? 270kg for reps is pretty huge, 180kg is nothing to be sniffed at either.
How bad is the pain?
Sonny go see a chiropractor or physio mate, Im sure they will sort it out quickly mate...
Sounds like some shoulder instability.
Hang clean to push press for reps (3X10) is an absolute killer!. i had to sit down after each set gasping for breath...il be doing these for reps more often![]()
Awesome exercise, crush so many muscles!Sonny go see a chiropractor or physio mate, Im sure they will sort it out quickly mate...
i reckon i might of done a delvis today. my shoulder is sore. i can move it any direction i want and i can pick up things and move them about no problem. its when theres resistance i get a sharp pain. for example if i stick my hand on a table top and lean on it slightly.
so if my arm/shoulder gets pushed into its socket i get pain, otherwise any other movement is fine.
i was doing overhead presses which i think caused it or it may have been the deadlifts. it was fine during all my sets, i felt a slight twinge but nothing major. and hour later and its giving me problems. hopefully by tomorrow it will be fine, but im going to rest it for 2 days and see how it is.
I'm sure my heart rate is right up there with when I do HIIT, body takes a hell of a beating![]()
Do any of you get much hatred for working out.
I nipped out in a tight fitting tee and got the full range of comments, made for an interesting afternoon, some very jealous and sad lads out there
One lass said, christ he's massive
Not really, aren't you the same person who had a girl at checkouts scared? Maybe smiling could help these problems![]()
.Thanks for your input.DarkShadow:
Perhaps you could cut the volume down and do 3 x 5 which would still alow you to lift heavy yet recover. Or possibly 3 x 6 or even 3 x 3.
Or you could even pyramid over the week for example:
Monday: 5 x 5
Wednesday: 4 x 3
Friday: 3 x 2
Increasing weight accordingly.
One big ascending pyramid, just another ideano idea on it's effectiveness!
3min mark - Just the right amount of jelly mmmhmm!
And she still looked so feminine in the right places!
