Installing Android etc:
Download these three files:
Fastboot, ClockworkMod (2.5.0.9), and your desired ROM - Modaco 2.2 in my case
You may also need these files downloaded prior to install when you plug the phone in via USB:
http://www.easy-share.com/1912504577/usb_driver.zip
http://android.modaco.com/content/zte-blade-blade-modaco-com/322611/official-zte-usb-drivers/
Step by step install instructions
* Download 2.5.0.9 ClockworkMod Recovery for ZTE Blade
* Download fastboot if you do not have it already.
* Turn off your phone and take out the battery. Unplug the phone from the PC / charger.
* Replace the battery and turn the phone back on with 'volume up' held. The device will stay at the 'green android' screen.
* Plug the phone into the PC.
* Extract the contents of the fastboot zip file into a directory on the C:/ drive
* From a command prompt (at the directory containing these new files!) run 'fastboot-windows flash recovery recovery-clockwork-2.5.0.9-modaco-r2-blade.img' (subsituting fastboot-mac' or 'sudo fastboot-linux' as required)
* When this finishes, from the command prompt run 'fastboot-windows reboot' (again substituting 'fastboot-mac' or 'sudo fastboot-linux' as required)
* Done!
Run the phone with Clockwork Mod on to see if its actually working still
THEN:
- Put the desired ROM file (Modaco 2.2) onto the SD Card WITHOUT extracting the contents, leave it in a zip file
- Turn the phone off, then turn it on while holding down the -Volume button down - The green Android should flash Blue
- You should now be in the Clockwork mod 'gui' as such...use the following commands to naigivate:
Navigation in the recovery image as follows:
* Volume Up / Down to move between options
* Home key to select an option
* Back key to go back
I seriously suggest backing up the original O/S / ROM here, just incase something goes wrong.
- You now need to select the 'wipe' option to wipe the phone
- Once done, select the option to install a .ZIP file from an SD card, then select the desired .zip file
- Once completed, select the option to clear the cache on the phone - Once completed, reboot the phone using the option on the menu
- You will see theg reen Android, it will then chage to the 'Modaco' image (If using the Modaco ROM)...This will last a couple of minutes, it should then load up into the new O/S / ROM
Think thats everything...I'll read it in a sec and see if it makes sense
