Damn this is such a good price for the performance on offer. If I wasn't on watercooling I'd have snapped two of these up and xfired them. However the cost of two plus two waterblocks puts the price well above a single 570
Would this be quieter than an ASUS 5770 (Egg Cooler Version)?
Unfortunately, I only have a 430W PSU.
I'll be sticking with my HD6850 upgrade this christmas then...
Put two orders in 1 for bits and an other for the GFX cards. You qualify for free postage as a forum member.
That's an interesting point. Are these boards reference? Would it be possible to put a standard 5850 water-block on them?
I was thinking I might switch out my water-cooled 4870x2 for one of these if I could water cool it. Would it be too much of a downgrade going from a 4870x2 to one of these?
If its a good brand should should be fine.
A bit angry, I have a severe case of upgratititis and already have a 5850 with a vf3000 and a thermalright vrmsink on it. No room for another and no need!
If I had my old geforce 9800 it would be crossfire in a heartbeat.
Hmm.. I forgot about the fact that it will be a non reference card so it probably wouldn't be possible to put a standard block on. Ek do a non reference block but it says it only fits asus v2 cards. It probably wouldn't be much of a downgrade, if any especially if you overclocked it. Also dx11 with the 5850.
It would be like around 5770-5830 speed.3.2Ghz E2180 will probably hold back the 5850. By how much roughly?.
I've got an AMD X6 chip, so the max temp for that is 62C. That's the only real reason I'm worried is that the GPU raises the water temp too much.
Also if i could reduce the heat of the loop I was hoping I could use a fan controller to stop the rad fans running at 100% all the time.
Quieter than a reference (sapphire HD5850) apparently.
I had a link but accidentally lost it. EDIT: http://www.overclock.net/ati/702833-msi-hd5850-twin-frozr-review-comparision.html
Isn't the temp you got when stress testing only like 52C or something though? That's when everything is maxed, so I can't really see why you would be worried personally. Stop being paranoid![]()
