You don't need to spend hundreds and hundreds of pounds to be in fashion. All it takes is a small bit of research (just look around and see what people wear when you walk down the high street) and perhaps browsing a few magazines. The trick is to buy a few "basics" and adjust your wardrobe accordingly.
http://www.fashionbeans.com/feature...–-part-15-–-the-other-6-items-you-should-own/
The above is a very good read. For example, a white t-shirt doesn't go out of fashion but the neckline and fit will always need to be slightly different depending on what you will be wearing. If you want to wear a neckchain, i personally prefer a more distressed looking t-shirt but if i am wearing a hoodie over the top (with the hoodie mostly done up), i don't need anything special and a normal crew cut would be fine. It's just common sense.
After a while i have become fussier about the brands i wear, to the point where i won't buy certain brands because of the way the logo looks or just the name.I wouldn't wear Jack & Jones, Fenchurch, Carhartt, G-Star, FCUK or Ringspun for example...just not to my taste as a brand.
Spot on, and largely echoes my own thoughts and research.
hehe well I am 23, 5'7 (so shorter than average) and 33" waist (could be slimmer, too much working away eating in hotels is not good for me) so I will be avoiding the slim fit jumper
By the time I have lost some weight the slim fit wardrobe is what I will be aiming for![]()
Don't be afraid to go with slim fit jumpers and shirts... they will still be flattering and make you look slimmer, and will continue to be wearable as you lose weight. Just make sure theyre not skin tight and you'll be fine.
