I just bought some coilovers. Late night on a whim purchase. Oops.
Which ones did you get? Don't forget the pics when you've had them fitted!
Do you think if I painted them red and didn't like them it would be easy enough to go over them again in black? Assuming I used a wire brush to get most of the red off?
got new brake discs to fit all round
Painted mine silver while they were on the car. Just make sure not to paint the pads otherwise it looks retarded! Though if you're changing the discs you'll have the caliper half apart anyway so might as well paint it with the line still attatched but not assembled.
What did you opt for? Brembo HC's & DS2500's were probably the best decision I made!
I was looking at Brembo HC's & Mintex M1144 pads. Have you got any experience with these?
People say they fade quicker on the track but are just as good on the road and there a lot cheaper than the DS2500's.
Brembo HCs and my current pads (which I assume are Renault ones), which have plenty of life left in them so just going to reuse them. Is that ok to do?
I wouldnt worry too much, just more of the noise thats the issue I think. How is it like going over bumps and such?
Clio looking nice and
Great seeing what you've done to it considering the problems you had to start off with. How much you spent on mods so far SS?
How much is that up for?
