I think most of us has the fanspeed stucked at 55% at default...we just use MSI Afterburner to set a custom fanspeed profile to overide the loud 55% fanspeed.Is anyone else finding the default fan speed is about 50% even when the gc is cool? As the fan profile in the bios says it should only get to 50% when about 70c.
Save it to a profile in MSI Afterburner, and try higher overclock and save to a different profile.got my card running stable at 850/1250 might try and puss it a little futher though
Hi im currently running 850 core, 1250 mem, v1.230 with a danger den maze 4 gpu water block.
ive saved my default profile which is 725/1000 but at idle core is 400 and mem is 1000?
Hi guys, just checking:
Would I be able to overclock this card as much as the one in my sig using Saph Trixx to synchronise clocks? Just wondering as I might be getting one of these for crossfire![]()
Ive got a MSI 5850 TF Crossfire setup. If I try to overclock by 1mhz using MSI Afterburner my system locks up. Using Cat 10.12 drivers. Don't know if it's the drives, MSI afterburner or a BIOS issue.
Just letting you know. See if anybody else has overclocked these cards in crossfire.
Hi there
This offer is back on as we've secured another batch.![]()
Mate you couldn't have a crack at using Trixx could you? It's the only program I could use to get my 5850 stable (needs 1.3 volts)
Cheers for the help, much appreciated![]()
Google is your friendit's on techpowerup and guru3d I think
im using 10.10 , i installed 10.12 but i keep getting an error saying driver not responding, i have tried it since and i still get it so i have put 10.10 back on, hopefully there will be a new driver our soon.
